Hi Shack,
Unfortunately there's not just a single VI that has all of the
functionality that you are looking for. LabVIEW is a programming
language, so while you may be able to find some already existing VIs
that have some of the functionality you desire, you will still have to
create the application on your own.
It sounds like you are fairly new to LabVIEW. If that's the case, then I definitely recommend that you take a look at the
LabVIEW Fundamentals page, particularly the
3 Hour Introduction to LabVIEW Course.
That being said you can really break your application into 3 parts:
- Read the Temperature from a Thermocouple - You can use the DAQ
Assistant (if you have LabVIEW 7.0 or higher) to quickly begin taking
Temperature measurements from a Thermocouple.
- Have some sort of logic to determine On/Off State - You might
want to just use a Greater Than function to say if a temp is greater
than Y to turn something off.
- Write Values to Digital Port - You can probably use the digital
port and write the values that you determined in step 2 and write those
values (as an array of 1D Boolean Data or something like that) to the
digital port on your board.
LabVIEW can help you do just about everything you want to do, but you
first have to break things into smaller pieces and then assemble the
pieces that you want to use into a larger application for your use.
