From 11:00 PM CST Friday, Feb 14th - 6:30 PM CST Saturday, Feb 15th, ni.com will undergo system upgrades that may result in temporary service interruption.
Digital I/O
The DIO96 card installed in the PC sets all the pins high on power up.(MAX test sets red lights on). is there a way to set them low on power up?
We are testing an eval board which needs to have low logic values to trigger devices.
(3,109 Views)
The answer to your question depends on which DIO96 board you have.
When the computer is first powered on, all lines on the board are configured for input. Internal "pullup" or "pulldown" resistors determine the logic state of the input line. If a pullup resistor is present, it connects the line to +Vcc (+5VDC); if a pulldown resistor is present, it connects the line to digital ground.
The PC-DIO-96 and PCI-DIO-96 resistors are 100k pull-up resistors and can NOT be set to pull-down.
The PC-DIO-96 PnP resistors are pulled up or down through a 100k resistor which can be selected by switching jumper W1.
(3,109 Views)
