Digital I/O
Testing switch array with PCIe-6509. High Z mode?
I have a large array of physical switches and buttons to test:
  1. Upon closure, each one must be under a certain resistance.
  2. Upon release, each one must be over a certain resistance.
I am testing this by placing each line into a PXI matrix switching card which is routed through to a DMM.  The user is prompted to go through the switch array in a predefined order testing each line individually.
However, I would like the end user to also be able to enter a separate "quick test" mode where they are able to press any of the switches at any time and get an indication on-screen that the switch is in reasonable working order.  The idea was to splice every line into a PCIe-6509 as well as the matrix/DMM
However, the problem is that any line on the PCIe-6509 is only 25kΩ with any other.  Is there a way to set all lines to a HI input impedance state so that when the first test is run I can test the actual resistance of the switch in its "open" state not the 25k as seen by the DIO?
Any input would be appreciated.
(2,541 Views)
Check out this forum post that is addressing a similiar issue to yours.
https://forums.ni.com/t5/Digital-I-O/6509/td-p/2128662
(2,497 Views)
