10-04-2022 06:57 AM
Hi all,
Does anyone know the correct way of using the words "channel" and "line", or are they synonymous? I would for example say that "a physical line in an I/O device is represented by a virtual channel in NI-MAX". But I would at the same time say that "an I/O device has 16 analog input channels". How to define a boundary between these words in a scientific paper without confusing the reader?
10-04-2022 07:34 AM
Well, it isn't quite that clear. A line is a single Boolean input/output. Then you have ports, which consist of multiple (usually 8, 16, or 32) lines which are accessed with numerics (U8, U16, or U32). A channel is a generic DAQmx term for an IO. For a digital channel, it could be a line or a port.
