05-23-2005 08:58 AM
05-24-2005 02:46 PM
07-25-2006 12:44 PM
07-26-2006
11:05 AM
- last edited on
08-19-2025
09:16 AM
by
Content Cleaner
Hello Jordan,
The counters on your DAQPad-6070E Multifunction DAQ device are capable of generating TTL pulse trains out of the PFI lines. Your device is only supported under the Traditional NI-DAQ driver so this will be a little harder to program than if it used the NI-DAQmx driver, but there are examples built into the driver software that provide a good starting point. You can access the Traditional NI-DAQ shipping example in the LabVIEW Example Finder under Help > Find Examples. I would recommend starting with the example titled Traditional DAQ > Counters > DAQ-STC > Generate Pulse Train (DAQ-STC).vi. You can find the default PFI pin used for counter output in the pinout diagrams for your device found in the E-Series Help Manual.
I hope this helps,
Travis G.
Applications Engineering
www.ni.com/support
07-26-2006 11:42 AM
07-30-2006 02:20 PM
