Digital I/O
Synchronise digital pattern output(6533) with a external signal
I use a PCI-DIO32HS and i want to synchronise an output pattern with an external signal(TTL;T=1.7ms).
ie :every time external signal become high(every 1.7ms)
my dio32HS output a define pattern on a line.
How can i do this?Thanks
(3,672 Views)
Wire your clock signal to the REQ pin for the group you are using. By default, the pattern is updated on the rising edge of REQ.
(3,672 Views)
Thanks for your answer but see attached file to see what i want to do.
I want to control delay between trigger(input signal T=1.7ms) and ouput and control the width of the ouput pulse
Best regards
(3,672 Views)
