Digital I/O
Suggest a card to sample 96 inputs with 5us pulse
Could someone suggest a solution and NI card to sample 96 inputs with a 5us pulse. PCIe would be preferred. The test setup would consist of stimulating the unit under test (UUT) and then sampling the UUTs 96 outputs to look for appropriate 5us pulse outputs. The objective is just to see that the UUT output changed state when commanded to.
(1,864 Views)
With the information you gave, I would be looking into the PCIe-6509. It has 96 I/O channels and seems like it would supply those 5 us you mentioned. You can check it up in the link I'm including below.
User Guide and Specifications
PCI/PXI/PCIe-6509
http://www.ni.com/pdf/manuals/372117d.pdf
However, to be able to suggest a more suited card, we could use some more information. What are you trying to look into? Frequency, duty cycle?
(1,831 Views)
