Digital I/O
Start states of the NI PCI 6503
Good morning,
I'm using an I/O Digital card NI PCI 6503 in order to send datas to an external electronic card. The I/Os are defined like this : 3 Outputs for adresses, 16 outputs for datas, and 5 outputs for control signals (enabled on states or rises).
I would like to define start states for each line. I tried to use the DAQmx function "Define start states", but I get an error such as "This device doesn't support that function".
Do you have an idea to define these start states ?
Thank you all,
B.L.
(2,513 Views)
Unless I'm wrong, the only way to set the power up states of this low cost interface is to use external resistors. See pages 3-10 to 3-13 in the user manual.
As you probably know, for more expensive interfaces, this can be done by software through MAX.
Screenshot of the properties window for a PCI-6509 (french version of MAX) :
Message Edité par JB le 03-19-2008 10:08 AM
(2,511 Views)
Ok, thank you !
I didn't saw that.
Have a nice day !
(2,505 Views)
