01-21-2015 03:09 AM
I have an NI 9411 that I'd like to connect to and I'm looking for a 15-pin D-SUB Twisted Pair cable.
I have spoken with NI sales and the best they can offer is the following, which is unfortunately not twisted pair:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/212301
They advised that I have a general look around on google/RS Components, which I've done. I've found quite a few straight-through
15-pin D-SUB cables but still can't seem to find one with twisted pairs.
Unfortunately, making my own cable isn't a viable option.
Has anyone ever used a cable like this and know where to buy one in the UK?
Thanks.
01-27-2015 03:16 AM
Hi Split_Brain,
Unfortunately theres not much I can do to help with the 15-pin D-SUB Twisted Pair cable. I've had a quick search on Google and haven't been able to locate the correct cable for your needs.
DanC12
01-27-2015 04:42 AM
Also looked for you at various sources in the UK and The Netherlands but came up empty.
In my case I would solder such cable myself but you don't want to do that.
Perhaps another solution is a flatcable with twisted pair. You can make such a cable without any special tools. If necessary you can use a bench-vice.
Kees
