09-22-2008 04:40 AM
I had several tries to move my PCI-DIO-96 card ( part number ASSY 182920B - 01 1995) from a G3 Macintosh to a G4. It seem that the card itself is incompatible with the PCI bus of the G4. In particular, I can read the CardBaseAddress but I cannot write at the MITE Base Address. I get an violation error.
Am I right to consider that this version of the card is obsolete ?
09-24-2008 10:40 AM
Which version of driver DAQmx Base do you use?And wich version of MacOSX? Please refer to the DAQmx base readme file; check the compatibility between drivers, OS and cards. How do you get those errors? Did you made a program with LabVIEW, using VISA low level functions and/or registry I/O operations?
Cordially,
09-25-2008 04:05 AM
My constraints are the following:
- I implement through a PCI-DIO-96 card a very simple interface between a Macintosh G3 and a data acquisition system (VME crate with a parallel port) through a 8 bit-data and 2 bits handshake, very similar to a parallel printer connection. The data rate can reach several kbytes/sec (random data).
- since 1995, the Macintosh G3 is getting older and older. I would like to switch now to a PowerMac G4 (digital audio)
- I can use any Mac OS system from 9.2 to 10.5
- I am programming in both sides (VME and MacIntosh) in the C language. (Labview seems an enormous hammer to kill this little fly.)
My first tries were not succesfull. May be I miss some information.
So I formulate my question more precisely: is my PCI-DIO-96 card compatible with the PCI bus of the G4 and does it exists any NI driver to make it work in any of these environment ?
10-06-2008 04:13 AM
I do not know the specifications of your PCI bus - I know that certain PCI hardware are not supported by the every versions of bus (voltage issues). I don't have any reasons to think that your card is not compatible. However, you must use a version of driver, which is compatible with MacOSX 10.4.
Did you correctly initiate the driver in your code? Take a look on the shipped examples, and use them as startup.
Cordially,
