04-05-2019 07:57 PM
My set up is as follows:
Comp1======USB-6509-CP======CP-100 I/O Connector Block
I want to be able to make a program in Visual Studios 2017 that will send a signal from one of the screw terminal pinouts to be received by another similar set up (wired together of course). Is there a way to do send such a signal without using DAQmx? Or am I dead in the water because Measure Studios doesn't support VS 2017 yet?
04-08-2019 11:05 AM
DAQmx is the driver you need. Measurement studio is just an extension of Microsoft Visual Studio that provides .NET tools for creating test and measurement applications. For doing this in Visual Studio 2017, have you seen the following article?
Measurement Studio 2015 with Microsoft Visual Studio 2015 and Newer
