10-09-2007 04:35 PM
10-10-2007 06:40 PM
Hi jcao,
Like you said you can only import ASCII and VCD formats to the digital waveform editor. We do not carry any application that will convert from those file formats to ASCII or VCD. What I will suggest is; if you are able to, write your waveform again in the “Digital Waveform Editor” or generating the ASCI file manually. There may also be 3rd party applications available that allow you to convert patterns in the file formats you mentioned to VCD or ASCII I’ve looked and Google but didn’t find anything that might help you.
I hope I was able to help.
10-12-2007 11:34 AM
HI Jaime,
Thanks for your reply. Finally I got a VCD file and imported it into the Digital Waveform Editor. However, I got the following message:
"To respect the timing information defined in the VCD file, the imported waveform must be generated with the following frequency: 20 GHz."
What does this mean? My clock signal is only 500Hz. Why do I need to change the rate into 20GHz?
Thanks a lot!
Jing
10-15-2007 12:49 PM
Hi jcao,
The Digital Waveform Editor imports VCD files and formats them in such a way that HSDIO devices can use them. This formatting includes setting up the necessary resolution to take into account the accuracy of each signal’s edge transitions and their relative positions to the clock edges. I believe the issue you are referring to is a result of the timing resolution that has been implemented in your VCD file. For example, if you are using Pico- or Femto- second precision you would need a possibly unrealistic device sample clock to handle it.
Below is another post which I think might be related to your issue. Although the primary topic concerns another error code involving the importing of VCD files, it goes on to discuss the resolution and accuracy of digital edge transitions in a VCD file and how this might affect the necessary sample clock rates.
Can't import VCD file in Digital Waveform Editor
If possible, it would be helpful to post an example VCD file that results in this error. I would be happy to take a look at the file and see if I can confirm that this is the cause of your troubles.
10-15-2007
03:24 PM
- last edited on
02-19-2025
12:22 PM
by
Content Cleaner
jcao,
Whenever we see the Digital Waveform Editor wanting to import a VCD file with an elevated generation frequency, it is almost always due to the fact that the VCD file has edge transistions that don't align to a specific cyclized boundary.
In your case you mention that your test pattern should be generating at 500Mhz. Therefore you would expect that edge transitions in your VCD file are only occuring every 2ns. However, what is actually happening, is that your VCD file has some edges that transition ~50 picoseconds before or after the 2ns boundary. This is causing the DWE to want to oversample data from your VCD file and generate at a higher frequency (20GHz) in order to preserve this precise timing.
Based on the warning message you mentioned in your post, I believe you are using an older Digital Waveform Editor. Possibly v1.0. I'd recommend updating to atleast v2.0. Version 2.0 added some new features to the VCD importing tool to address this oversampling issue. The new feature allows you to import data from your VCD file at specific intervals of time. The specific internval can be based on a clock signal within the VCD file, or based on a user specified interval. The benefit of using a specific interval or clock signal for importing is that any edge that is just a few picoseconds outside of the expected boundary will be either pulled into the previous boundary or pushed out to the next boundary.
You can download a trial version of the DWE v2.0 from our website, NI.com.
https://www.ni.com/en-us/shop/product/digital-waveform-editor.html
Look for the Resources tab, and you will see a link to Evaluation Software.
The last post from Chris J B refers to a very old post which does not detail how to get around the issue, but that post does contain a detailed description of why the DWE is trying to import your VCD file with a 20Ghz clock.
Message Edited by JaredW on 10-15-2007 03:30 PM
10-15-2007 04:02 PM
Thanks a lot Chris and JaredW.
May I correct you that the clock signal is 500 HZ with period of 2ms? Will your analysis still be applied with 500Hz signal?
Yes, the digital waveform editor I am using is version 1.0. Thanks for the link. I will update to version 2.0.
Jing
10-15-2007 04:31 PM
10-26-2007 03:49 PM
I downloaded DWE 2.0 demo and tried to import VCD file.
As a first try, I imported only a 500HZ CLK signal at "select signals", "Select Sampling Method" as "Fixed Timebase or Rate", choose "Cycle Time for Sampling" as 10ns, "Frequency for Sampling" for 100MHz, "Sampling Starting Position" as 5ns, "Configure X and Z states" all as default. After I click "Finish", the error message is
"Waveform must contain 2 or more samples."
Can anybody help me on this? This is so frustrating. It's supposed to be a fairly simple process. I don't understand why DWE just can not do it!
Jing
10-26-2007 04:27 PM
Jing,
Your settings sound resonable assuming the signal you selected in import really is a 500Hz signal.
The DWE has a requirement that any waveform it has open in memory must contain no less than 2 samples of data. If a waveform file or imported VCD file only has 1 or 0 samples of digital data, the DWE will give an error and cancel the open/import operation.
There may be an issue in your VCD file. Maybe the timing that you expect the VCD file to have is not the actual timing. I would like to get two pieces of info from you.
1) Go to the VCD Wizard configuration page were you set the import timing. Instead of doing 100MHz, could you instead click the "Retrieve From File" button and then post the results that it finds into the message post. This button will scan the file and try to find the best import timing for the signals you selected to import.
2) I would like to get a look at your VCD file. Maybe not the entire thing, but a snippet of the first handfull of timestamps. Could you either add your VCD text file to this thread, or maybe edit it in a text editor such that we could atleast see the header for the file and a handfull of timestamps?
Jared
10-26-2007 05:11 PM
Hi JaredW,
Thank you so much for your help!
1. Yes, I indeed tried to "retrieve from file" to get the information of sampling frequecy. Unfortunately I got this error message:
"Import sampling configuration is invalid. The selected cycle time or frequency may be invalid."
The "Cycle Time for sampling" is 0s, Frequency is Inf Hz, while Sampling start position is 0s.
2. Attached please find the vcd file. It's a short version, the first 5 vectors only.
