10-10-2012 05:04 AM
Hi all,
I'm pretty new to LV programming and working a lot with NI 6212. Now I need to make a sample clock output so I can connect it to my Data Translation.
In general my set up is that I sample all 10 AI in NI and DT I have 3 analog outputs. I tried to understand it from examples and numerous posts about routing out sample clock and I simply get lost.
Would much apritiate any help regarding both issues:
*How I route sample clock to I suppose 1 of digital channels (PFI0 for example) ion DAQmx
*How I import external clock into DT 9834.
Thanks in advance,
Jenia
10-11-2012 03:41 PM
Hi Jenia,
This link should get you started on your first question:
http://ae.natinst.com/public.nsf/web/searchinternal/3a7f1402b2a1ce7686256e93007e66c0?OpenDocument
Data Translation will probably be a better source for find out how to import an external clock to the DT 9834:
http://www.datatranslation.com/products/dataacquisition/usb/DT9834/
