06-03-2011 06:11 AM
Hi all,
In the test panels for my DAQ card, I can see a nice LED display for the states of the digital inputs. It would be extremely useful if I could have the same thing on the front panel of my program. Is there a way to do this?
I tried using DAQ assistant, but it outputs an unusable 1-D boolean array, which, after trying to convert into something useful, such as numbers, dynamic data, strings etc, there appears to be no change in data - it remains as zero. Ideally, I would be able to convert the 1-D boolean array to a real time boolean value.
In the test panels, I can see the led lighting up when the trigger signal is detected. I am using the PFI0 to trigger the start of analogue input acquisition, so I need to know when the trigger is detected.
Thanks for reading, I hope you can help!
06-03-2011 10:05 AM
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
