10-01-2019 01:18 PM
I have an FPGA which is sending data off on the GPIO pins. I want to read these bits in parallel and then send them to my pc over a USB cable. I have been looking at a couple different options to do this including the USB 6501. Is this device a good option for this application or is there a better option out there.
Thanks in advance.
10-01-2019 01:33 PM
Which FPGA card?
10-01-2019
02:47 PM
- last edited on
11-03-2025
04:06 PM
by
Content Cleaner
Is there a clock line with the data?
If so you will need a card that can do hardware timed or correlated digital IO. From memory the 6501 can't do this. I think this is the comprehensive list: https://www.ni.com/docs/en-US/bundle/ni-daqmx/page/sampleclockdio.html
10-02-2019 09:50 AM
Thank you for the responses.
I am using a DE2-115 Board with a Cyclone IV FPGA.
There is no clock line with the data.
I am wanting to send each bit off of its own pin on the GPIO port and have the NI DAQ take those bits and send them to my PC over a USB connection.
