06-08-2017 08:55 AM
Currently, I am designing the RMC board that is used to connected to sbRIO9627. In our application, the GBE (after PHY), High speed USB and C series DIO are not used. How should I address these pins on the RMC connectors? Should these pins be float? or pulled up by a resistor?
06-09-2017 04:45 PM - edited 06-09-2017 04:51 PM
Sounds like you only need to pull-up if you need to set startup or unconfigured state. If the pins are not being used for anything, it should be fine to let them float. Check the slides attached, they are pretty informative. See also this design guide (less helpful).
NI sbRIO-9607/9627 RIO Mezzanine Card Design Guide
06-16-2017 08:40 AM
Thank you for your reply. Actually, I have read this guide before. I think the design guide is kind of helpless. It dose not mention how to address those pin when they are not used. It seems that the attached slides do not mention them yet.
06-19-2017 06:53 PM
Did you see this manual as well?
NI sbRIO-9607 User Manual
http://www.ni.com/pdf/manuals/375463a.pdf
From p. 29:
Note Leave reserved and unused pins disconnected on RMCs.
04-23-2020 07:22 PM
Thank you AvatarAang!
The slide you shared is quite helpful.
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
