Digital I/O
RDIO vs. RMIO cable for an MIO PCIe terminal
I have very little electronics experience, so I apologize in advance if this question is inappropriate or dumb.
I want to use analog voltage signals (0 to +10V) to control a device that is connected to a PC via the DIO terminal block of a PCIe card. I plan to supply the voltage signals through BNC connections to a connector block (NI# CB-68LPR) that, according to the documentation I'm following, should connect to the MIO PCIe terminal via a SHC68-68-RMIO cable. I don't have any of these, but I have plenty of SHC68-68-RDIO cables. Are they interchangeable?
Thank you in advance!
(116 Views)
Hello!
Yes, the cables are interchangeable. Here is some additional information about R Series cable and accessory compatibility.
(83 Views)
