Digital I/O
R1005050 PCB Connector
I am designing a PCB for connecting with PXI6511 and PXI6512 modules with R1005050 connector. I have not found any technical information about this connector, so I am not sure about the PCB headers I must use.
I know that I have to use IDC50 conector, but which is the pitch? 2.54mm, 2mm or 1.27mm. Is there any reccomended header?
I know that there is the same question made, but I don't know if the answer is for the cable pitch or the connector pitch, and a part of that, the technician who answered appears to be retired, so I would like to ensure about it and if possible, I would appreciate a technical document with drawings of R1005050.
Thank you in advance and best regards.
Message 1 of 8
(5,539 Views)
Is your question about the mating connector for this IDC connector of the cable?
https://www.ni.com/en/support/documentation/supplemental/18/r1005050-and-nb5-ribbon-differences-and-...
Santhosh
Soliton Technologies
Message 2 of 8
(5,512 Views)
Hello Santhosh,
Yes, I am asking about the IDC 50 connectors.
Thank you and regards.
Message 3 of 8
(5,509 Views)
I couldn't find information to confirm the pitch, but those look like regular 50-pin 25x2 0.1" spacing IDC or header pin connectors.
https://www.ni.com/en-us/support/model.r100m-50f-50f-cable.html
Santhosh
Message 4 of 8
(5,486 Views)
Dear Santhosh,
I really appreciate your answer. For me it also looks like regular 50-pin 25x2 0.1" spacing IDC header pin connectors, but I can't base my design in guesses after looking a picture. I understand that a company like NI should have an official drawing with meassures, or at least mention them in the product page or somewhere.
I hope i could have an official answer about.
Message 5 of 8
(5,477 Views)
If you're anyway going to order the cable, get the cable and confirm it before finalizing your board design. It is not an expensive cable compared to others.
Santhosh
Message 6 of 8
(5,456 Views)
Accepted by topic author EgoitzTI
Having such connectors at my disposal, I've just taken a photo. The scale is in [mm].
Message 7 of 8
(5,448 Views)
That means 2.54mm pitch, thank you for your help!
Nevertheless, I think NI should consider to upload official technical drawings not to happen things like this...
Thank you again.
Best regards.
Egoitz.
Message 8 of 8
(5,443 Views)
