Digital I/O
Question about PXI-6562 pin flipping
I have a PXI-6562 card with the cable that has the note.
Note  If you design a custom cabling solution with connector (779157-01) and cable (192744-01), the NI 656x pinout is reversed at the end connector. For example, the signal shown on pin 1 shown in the previous figure would map to pin 73 at the end connector.
Pin 1 flips to Pin 73, but what about the pairs?
Does Pin 2 flip to 72 or 71?
(3,642 Views)
Hi Steve,
Going off of the NI Digital Waveform Generator/Analyzer Getting Started Guide, look at Figure 15 for the custom cable connector solution pin out, which is reversed from the normal pinout on Figure 14.  All pins are reversed.
Kyle A.
Senior Applications Engineer
(3,618 Views)
Accepted by topic author Steve_Block
1 - 73
2 - 72
73 - 1
All signals pin numbers add up to 74
"Should be" isn't "Is" -Jay
(3,617 Views)
