Digital I/O
Port/Pin connection chart for cDAQ 9171
I'm looking for a diagram and/or table that lists the ports and their respective pin numbers for the 9171 USB Chassis. Does such a document exist?
(4,901 Views)
The 9171 is just a chassis. What IO module do you have?
(Or do you wan to make your own module?)
(4,885 Views)
Below is the link for the user manual to the NI cDAQ-9171 as well as the spec sheet for the NI cDAQ-9171:
NI cDAQ-9171 User Manual:
(1.) https://www.ni.com/docs/en-US/bundle/cdaq-9171-9174-9178-features/resource/372838e.pdf
NI cDAQ-9171 Data Sheet:
(2.) http://www.ni.com/datasheet/pdf/en/ds-178
I hope this helps!
(4,864 Views)
The NI 9403 I believe.
(4,861 Views)
So you want the pinout for the module, not the chassis. That should be easy to find.
(4,857 Views)
Page 10 of this document appears to have the pinout diagram for the NI 9403:
NI 9403 Getting Started Guide:
https://www.ni.com/docs/en-US/bundle/ni-9403-getting-started/page/overview.html
Is this what you are looking for?
(4,840 Views)
It is not that easy. I still didn't see this pinout anywhere... (the sub-D module connector to the rest of the system)
(244 Views)
