Digital I/O
PXIe-6570 connectors (VHCDI)
I use a 68-Pin, Right-Angle VHDCI Connector, NI PN 778914-01 with a PXIe-6570 Digital I/O card.  The through hole pins from this connector are very fine pitch, about 0.05". This stresses the PCB and is not very robust for STS production test.
Does anyone have a connector for the SHC68-C68-D4 cable with 0.1 inch spaced holes to the PCB? Any ideas appreciated.
(2,586 Views)
It's clear this was a long time ago but I bet the answer here was to change the cable you're using altogether.
https://www.ni.com/en-us/support/documentation/dimensional-drawings/model.shc68-68-rdio.html
Thay way you can look for a different/bigger connector that'll suit your needs.
(1,242 Views)
