Digital I/O
PXIe-6570/PXIe-5433 : Can I get a real time digital pattern waveform with these modules?
PXIe-6570 : 32-Channel Digital Pattern Instrument
PXIe-5433 : 80 MHz Bandwidth, 16-bit PXI Waveform Generators
I learned to export digital patterns using PXIe-6570.
However, I wonder if I can receive digital patterns from this module and save data in real time like an oscilloscope and what programs I should use if possible.
I think what I understand is only possible to load a digital pattern data file (.csv) from that module.
However, if you can show me the digital pattern in real time, i would appreciate it if you could let me know a brief method.
In addition, I think we can get a digital trigger signal using PXIe-5433, so I'd appreciate it if you could tell me if this can also be checked in real time and how to do it briefly.
I can't understand even if I read the manual, so I post it. I'd appreciate your help.
Other modules and parts I have
: CB-2162(Single-Ended Digital I/O Accessory
(1,550 Views)
In terms of 6570, there is no readily available way to capture the signal like a digital logic analyzer or an HSDIO 655x. The easiest way would be to create a pattern that captures data on all the channels for all vectors and you can save this U32 array to a file either from Digital Pattern Editor or using any ADE (LV, C# etc.,).
In terms of triggers, yes, you can route the trigger from 5433 to 6570 (for example, start trigger to do a stimulus capture)
Note: meaning of real-time differs, nothing is real-time as there will be delays as the signal propagates through each element, even a scope is not real-time, it captures for x duration and display it afterwards.
Questions,
  • How are you using the 6570, only from Digital Pattern Editor manually or using an ADE?
  • How familiar are you with automating 6570?
  • What kind of synchronization are you looking to achieve between 5433 and 6570?
  • Could you provide more details about your application to guide you better?
Santhosh
Soliton Technologies
(1,521 Views)
It sounds like what you want is something similar to Capture memory - https://zone.ni.com/reference/en-XX/help/375145F-01/digipat6570/capture/
It's not quite like the digital logic analyzer on an oscilloscope, but it's a similar concept. Does this meet your needs?
Brian Morgan | NI Software Engineer, R&D
(1,516 Views)
I couldn't reply for a long time because of the project. I'm sorry.
I think I wrote the meaning of real-time wrong.
I wanted to know the constant period of the pulse signal measured even though there was a delay.
What I wanted to do was to receive the pulse signal in a certain period and measure the period.
To measure the period it doesn't matter if signal displayed or digital signal data is listed.
=> Does this mean signal > 5433 > 6570? I don't understand...
Questions,
  • How are you using the 6570, only from Digital Pattern Editor manually or using an ADE? => yes, only from Digital Pattern Editor manually to use 6570
  • How familiar are you with automating 6570? => I don't know about automation, but I set them all myself using a digital pattern editor.
  • What kind of synchronization are you looking to achieve between 5433 and 6570? => 6570 was used to send digital signals through a digital pattern editor, and as mentioned earlier, I would like to use 6570 or 5433 to read digital signals.
  • Could you provide more details about your application to guide you better? => If you are talking about information on digital pattern editors, I will attach it below. The picture below is part of the setting manual for using the digital pattern editor I made. (Originally, the Korean version.)
Thank you for your interest and answer.
If I can't find the answer in the end because I lack comprehension, I'm just going to use an oscilloscope. 😞
(1,452 Views)
@BrianMorgan  작성:
I read about capture, too. I didn't understand the meaning of capture... 😞 Thank you for your answer.
(1,450 Views)
