Digital I/O
PXIe 6363: Maximum current output for AI channels?
Hello All,
I'm using PXIe 6363 (10V) to acquire data from four sensors with 10k ohms impedance each. That means I need at least 4mA current to drive the sensors (4 x 10V/10000ohms = 4mA). How much is the current rating for AI channels of PXIe 6363 and where do I find this information? Thank you.
(3,266 Views)
AI stands for Analog "Input" and inputs don't supply current.
Santhosh
Soliton Technologies
(3,244 Views)
So I will have to power my sensors through external power supply? Thank you.
(3,240 Views)
Accepted by topic author solanki7788
You can use the +5V terminals on each connector to power your sensors.
What sensor are you powering? does it have to be strictly 10V?
Santhosh
(3,229 Views)
Thank you for the screenshot!
I have four linear potentiometers to measure displacements which need 10V (and have 10kohms impedance), so the 5V terminal might not work.
(3,222 Views)
