Digital I/O
PXI-6570 Max Safe Voltage
Hi All,
What is the maximum safe voltage for a PXI-6570?
I know that 6 V is the maximum voltage that PXI-6570 can output, but what is the maximum voltage that it can withstand?  Can it withstand 8 V?
(1,102 Views)
Accepted by topic author wcon0
It can support up to 7V in extended range but anything above will trigger an over-voltage shutdown.
If your external circuit can go up to 8V it is recommended to isolate them using an electromechanical relay to avoid irrecoverable damage to your instrument.
Santhosh
Soliton Technologies
(1,095 Views)
Thanks, Santosh,
Much obliged!
(1,092 Views)
Better to add a couple of $ worth relay safety circuits than damage an expensive $$$ equipment.
Santhosh
(1,081 Views)
Thanks, Santhosh!
(875 Views)
