Digital I/O
PXI-6570 Max Safe Voltage
Hi All,
What is the maximum safe voltage for a PXI-6570?
I know that 6 V is the maximum voltage that PXI-6570 can output, but what is the maximum voltage that it can withstand?  Can it withstand 8 V?
(1,113 Views)
Accepted by wcon0
It can support up to 7V in extended range but anything above will trigger an over-voltage shutdown.
If your external circuit can go up to 8V it is recommended to isolate them using an electromechanical relay to avoid irrecoverable damage to your instrument.
Santhosh
Soliton Technologies
(1,106 Views)
Thanks, Santosh,
Much obliged!
(1,103 Views)
Accepted by wcon0
Better to add a couple of $ worth relay safety circuits than damage an expensive $$$ equipment.
Santhosh
(1,092 Views)
Thanks, Santhosh!
(886 Views)
