03-01-2022 04:53 PM
Hi All,
What is the maximum safe voltage for a PXI-6570?
I know that 6 V is the maximum voltage that PXI-6570 can output, but what is the maximum voltage that it can withstand? Can it withstand 8 V?
03-02-2022 11:31 AM
It can support up to 7V in extended range but anything above will trigger an over-voltage shutdown.
If your external circuit can go up to 8V it is recommended to isolate them using an electromechanical relay to avoid irrecoverable damage to your instrument.
03-02-2022 11:33 AM
Thanks, Santosh,
Much obliged!
03-02-2022 05:25 PM
Better to add a couple of $ worth relay safety circuits than damage an expensive $$$ equipment.
04-26-2022 12:54 PM
Thanks, Santhosh!
