09-11-2007 02:34 PM
I have a PXI chassis with 3 HS-DIO cards installed in slots 3, 5, and 7.
I developed a simple CVI program that tests each card to make sure each card is functioning.
All the program does is start a generation and acquisition session on each card, and then it bursts and compares (HWC) data.
From the initial power-on, I can run the test on each card and it works. I've run the test several times.
However, if I issue a "reset" command in MAX on slot 3, I get back:
Error -239022 occurred at Device Reset.
Possible reason(s):
Internal Hardware Error occurred in MIG hardware. Please contact National Instruments support.
If I try and reset it again, it always returns this error.
If I reset card 5 a couple times, I start getting this error.
I never get this error on card 7.
I have MAX 4.3 and installed the latest DAQmx and HS-DIO drivers today.
09-11-2007 04:24 PM
09-11-2007 07:25 PM
09-12-2007 03:08 PM - edited 09-12-2007 03:08 PM
Hi Jakeus,
This error typically signifies that the card needs to be sent in for repair, as this is an internal error. Does this error occur when you do a self-calibrate in MAX? What about when you reset the device programmatically using the ‘niHSDIO_ResetDevice ‘? Have you tried the cards in different slots or chassis to see if the error occurs? After all this, if the card is still failing, please call a sales representative at 1-866-433-3488 to repair the board.
Message Edited by David L. on 09-12-2007 03:08 PM
