Digital I/O
PXI-6534 rewriting IO buffer with DAQmx causes error -200288
Hi.
I'm trying to rewrite the buffer on the PXI-6534 with the DAQmx drivers, but after some itterations it gives me error -200288. Seems like the previos opperation is not complete, even if I insert the wait function. How can I solve this problem?
Attached is an example of what I'm trying to achive.
- Steinar
(4,856 Views)
Hi Steinar,
Try setting the DAQmx Write : Regeneration Mode Property to disallow regeneration.  The default regeneration mode for sample clock timing is to allow regeneration.
Jeff
(4,840 Views)
I also get error -200288.   I have the NI 6534, DAQmx, C++ outputing::
DAQmxCfgBurstHandshakingTimingExportClock
DAQmxWriteDigitalU8
There is other code, but this is the core of it.  I can send between 1 and 4 GB (yes Gigabytes) of data, and then I get error -200288.  It seem to come at a totally random time, sometimes after about 1 GB, then 3 GB, 0.5 GB.
Is the fix truly to disable the auto-regeneration mode?
Kip Leitner
Panasonic
(4,695 Views)
I too am getting the same Error . I tried to modify the buffer , which I think caused the error.
I am ,however unable to modify the DAQmx Write because its a clone.
Obviously, i am not really familiar with labview and I now need to figure out how to modify a clone VI.
Thanks ,
Karthik J.
(4,031 Views)
