07-25-2019 09:59 AM
My PXI 6512 task is giving an error saying that its not supported. Is it not possible to generate a continuous pulse using PXI-6512 ? I am using onboard clock as clock source. What should be the clock source? Example program given in LabVIEW for Digital IO continuous waveform generation is also giving an error for PXI-6512?
08-01-2019 10:18 AM
Hi satcr,
Can you post a screenshot of that specific error? That will give some specifics to what could be going on here.
Best,
08-02-2019 07:42 AM
Sir,
Please find the error message screenshot
08-02-2019 10:24 AM
Hi satcr,
Can you try to delete this property node and rewire?
Best,
08-02-2019 10:39 AM
This is a code from LabVIEW examples under help for digital outputs under daqmx
08-02-2019 10:52 AM
Hi satcr,
Yes, but for this particular card, that property is unsupported. You can find the properties that are supported at the link below. The PXI and PCI form factors will share most if not all of those supported properties.
NI PCI-6512 Supported Properties
http://zone.ni.com/reference/en-XX/help/370471AM-01/cdaqmxsupp/pci-6512/
Best,
08-04-2019 11:40 PM
Hi Claire,
Even after removing this property node same error is coming. Actually error is getting generated at Daqmx Timing Vi itself.
08-05-2019 02:08 AM
PXI-6512 only supports on-demand timing, which means it cannot import hardware clock to generate the ON/OFF signals. Therefore, you cannot use DAQmx Timing VI. The only way to somewhat implement on/off is to use a while loop with some timing VI such as Wait Until Next VI and put DAQmx Write VI within it.
08-06-2019 03:41 AM
Ok.. In that case how to get a deterministic 10 kHz pulse on its output? How to make my timing vi deterministic?
08-06-2019 07:36 AM
Due to hardware limitations of not being able to output signal based off of hardware clock, it is not possible to output 10kHz signal with PXI-6512. You will have to get another device that support hardware timed DIO such as PXIe-6535.
