Hi, I've a problem to configure timing acquisition of PXI-6509. I'd like to sets the source of the Sample Clock, the rate of the Sample Clock, and the number of samples to acquire. I used the following function:
The error you reported is a CVI-DAQmx error. What is important when you receive any DAQmx erro is the error code.
Error 200077 means that the operation you are trying to perform or the values you selected are not supported on the device you are using. You might be designating options for the data acquisition that are not available on your device, such as in triggering or clock configurations..Also, whenever you get the error -200077, LabWindows/CVI will indicate why the error is occuring. More often than not, it is because the value that you have requested is out of range. In order to correct this error, note what the accepted value range is and change your configuration accordingly.
