05-04-2020 08:43 AM
The PXI-6289 module includes two connectors, left and right.
I need only 8 I/O for my circuit design. So, can we use/connect only one connector?
I have heard that we have to connect both in order to function. I double about it.
Please advise!
05-04-2020 10:46 AM
It should be fine to use just 1 connector. I'd recommend connector 0 because the pinouts on connector 0 tend to be compatible with many other NI multifunction devices. It'll have the signals that almost *all* multifunction devices support. Connector 1 is where the device-specific signals are found.
-Kevin P
05-04-2020 02:33 PM
Thank you!
Mike.P
