Digital I/O
PCI6024e card causes a plug and play configuration error upon statup
Any idea why a NI PCI6024e card causes a plug and play configuration error upon statup on certain PCs, while working fine on PCs of the same model?
(3,712 Views)
UNH,
Thank you for posting on the forums. I am curious as to what type of PCs you are using in the application. If the computers are the same model is it possible they have different motherboards or different versions of the BIOS on the different PCs. What is the exact error it is giving you when you start the computer?
Aaron W.
(3,690 Views)
