Digital I/O
PCI CAN Datasheet/Specs
Im trying to track down a datasheet for an old NI PCI CAN card I have see images attached. Im trying to find what versions of windows its compatible with.
Thanks in advance
Anthony
(3,563 Views)
Hi Anthony,
I have found the old datasheet on our web-site: http://www.ni.com/pdf/products/us/3ic744-747.pdf
About the Windows compatibility: The card works with the NI-CAN driver and every driver version is compatible to the windows version of their time.
The newest version 17.0 is compatible to Windows 7+8+10, but if you need an older Windows you will certainly find an older driver version compatible with it.
I post the link to the newest version here: https://www.ni.com/en/support/downloads/drivers/download.ni-can.html#344639
Andreas
Andreas
CLA, CTA
(3,537 Views)
Note: Your card has the RTSI connector.  These cards were first available in the mid to late 90's.
See: https://www.ni.com/en-us/support/model.pci-can.html
It will show a series 2 card while yours is a series I.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(3,532 Views)
