Hi-
I have a brand new PCI-6515 DIO card that we just bought. Windows' Add New Hardware wizard recognizes the model of the card, but hangs while installing the driver (just after it says "creating a system restore point"). The computer is running Windows XP SP 2. I've tried using NI-DAQ 7.1, 7.3, and 7.4; all fail in the same way. I've tried three different PCI slots; the slot the card is in doesn't matter. I've also tried installing the card with no other cards installed, and with the following cards installed:
1) network card
2) network card, PCI-DIO-96, PCI-6711, PCI-6023
The computer is an Advantech Industrial Computer 610, 256 mb of memory, 700MHz Pentium 3. The other NI cards (PCI-DIO-96, PCI-6711, PCI-6023) don't have a problem; the drivers install correctly and NI-DAQmx recognizes them.
The PCI-6515 card does seem to work in a Dell Dimension (2.4GHz celeron, Windows XP SP 2, Ni-DAQ 7.1)...so, I don't think the card itself is completely defective. (But, I cannot permanently use the Dell computer for this card - I borrowed the computer from another task only to test this card).
What do I need to do to get the PCI-6515 card to work in the Advantech computer?
Thanks!
