yI am trying to develop with the PCI-DIO-24 (PCI-6503) in VC6 / Ni-DAQ version 7.4. I simply want a function to be called when a digital input goes high or low. but the callback function always be no response.Have anybody can help me to find what's wrong?
my code: basis of DAQTest.zip #include <afx.h> #include <afxwin.h> // MFC core and standard components #include "nidaqex.h" #include <iostream> using namespace std;
void __stdcall OnDataCallback(HWND handle, UINT msg, WPARAM wParam, LPARAM lParam) ;
void main(void) { int nRetCode = 0;// initialize MFC and print and error on failure if (!AfxWinInit(::GetModuleHandle(NULL), NULL, ::GetCommandLine(), 0)) { cerr << _T("Fatal Error: MFC initialization failed") << endl; return; } i16 iStatus = 0, iRetVal = 0, iDBmodeON = 1, iDBmodeOFF = 0, iDevCode = 0; i16 iSampTB = 0; u16 uSampInt = 0; i16 iHalfReady = 0; i16 iDAQstopped = 0; u32 ulPtsTfr = 0; i16 iIgnoreWarning = 0; i16 iGain = 1; i16 iUnits = 0; u32 ulCount = 1000; f64 dSampRate = 2.0; static i16 piHalfBuffer[50000] = {0}; i32 lTimeout = 180;
i16 iDevice = 1; iStatus = Init_DA_Brds(iDevice, &iDevCode); iRetVal = NIDAQErrorHandler(iStatus, "Init_DA_Brds", iIgnoreWarning);
i16 iChan = 0; int iMode = 1; int iDirection = 0; iStatus=DIG_Prt_Config(iDevice,iChan,iMode, iDirection); iRetVal = NIDAQErrorHandler(iStatus, "DIG_Prt_Config", iIgnoreWarning);
CString strChan; strChan.Format("DI%-d",iChan); const int nMaxStrChan = 128; i8 FAR chanStr[nMaxStrChan]; memset(chanStr, 0, nMaxStrChan); strcpy(chanStr, (LPCSTR)strChan);
i16 nDAQEvent = 8, nAddMode = 1; i32 nTrigVal0 = 1, nTrigVal1=0,nIgnor = 0; iStatus = Config_DAQ_Event_Message( iDevice,nAddMode, chanStr,nDAQEvent, nTrigVal0, nTrigVal1, nIgnor, nIgnor, nIgnor, NULL, NULL, (unsigned long)(&OnDataCallback)); iRetVal = NIDAQErrorHandler(iStatus, "Config_DAQ_Event_Message", iIgnoreWarning);
i16 iGroup = 0; i16 iGroupsize = 1; static i16 portList[1] = {0};
iStatus = DIG_SCAN_Setup(iDevice, iGroup, iGroupsize, portList, iDirection); iRetVal = NIDAQErrorHandler(iStatus, "DIG_SCAN_Setup", iIgnoreWarning); static i16 piBuffer[100] = {0};//accept 100 items only iStatus = DIG_Block_In(iDevice, iGroup, piBuffer, 1000); iRetVal = NIDAQErrorHandler(iStatus, "DIG_Block_In", iIgnoreWarning);
printf(" Continuous acquisition has started.\n"); printf(" HINT: You can add your own graphing calls in the while loop.\n"); TRACE(" Continuous acquisition has started.\n"); TRACE(" HINT: You can add your own graphing calls in the while loop.\n"); while (iLoopCount <10) { if (iLoopCount) { printf(" get call back %d!\n",iLoopCount); break; iLoopCount++; } ::Sleep(5); }
printf(" Continuous acquisition is done!\n"); TRACE(" Continuous acquisition is done!\n"); /* CLEANUP - Don't check for errors on purpose. */ iStatus = DAQ_Clear(iDevice); iStatus = DAQ_DB_Config(iDevice, iDBmodeOFF); iStatus = Timeout_Config(iDevice, -1); }
void __stdcall OnDataCallback(HWND handle, UINT msg, WPARAM wParam, LPARAM lParam) { i32 iPattern=0; DIG_In_Prt(1,0,&iPattern); iLoopCount++; // TRACE("CNIDAQBoard::OnDataCallback #%d\n", iLoopCount ); return; }
