Digital I/O
PCI-6036E drivers for windows 10
Hello all,
I have a fuel system test bench that is still running on Windows XP and needs to be updated. All analog instruments connect to NI 5B02 16 Channel Backplane, which connects to a NI SC-2050 Cable Adapter, which then is connected to the PCI-6036E Card via a CB-50 Cable.
My plan is to upgrade the LabVIEW version to 2015, fairly straight forward, and find the appropriate drivers for the PCI card.
But my question is are there any drivers for the PCI card that are compatible with windows 10? And will the newer 2015 version of LabVIEW be backwards compatible with the PCI card?
(3,234 Views)
last version is 19.  refer to DAQmx 19.0 readme below,
https://www.ni.com/pdf/manuals/374768ab.html
But, All DAQmx do not support PCI-6036E under Windows 10 64bit.
You can use Windows 10 32bit.
(3,201 Views)
"But, All DAQmx do not support PCI-6036E under Windows 10 64bit."
This is what the readme says. However, we have a 6036E running under Windows 10 64bit without any errors.
Greetings,
Lars
(2,100 Views)
Greetings,
Lars
When NI states it will work, they have tested it to work. In your case, they may have not tested, and hence, they did not warrant that it will work. you're lucky that it works, but no one knows what cases it may not work.
Santhosh
Soliton Technologies
(2,092 Views)
