Digital I/O
PC crashes after installing HSDIO
PC:  Dell vostro-5890, i5 11400F 8G, win 10 system
I try to build a time sequence with PCI-6542. Since the card is too big, I connect the card to my mainboard through a PCIe-PCI patchcord.
After the connection, PCI-6542 appears in NI-max but with no driver(labeled with a '!'). So I installed HSDIO, and reboot the computer. The computer goes crashed each time on the interface where the password is required. I can enter the system only after unplug the PCI-6542 card.
Do you know that is the problem and how to solve it? Thanks a lot,
Wang
(1,246 Views)
Accepted by zhuodashi
Simple, get a motherboard with a PCI slot.
FYI - PCIe to PCI adapters are not supported by NI cards, it is just because that PCIe to PCI do not function exactly the same as a PCI bus and hence the missing low-level functionalities cause the card to malfunction.
Santhosh
Soliton Technologies
(1,243 Views)
Thank you so much for your advice!
(1,233 Views)
