I have PCI-6509 96 Channel Digital I/O which was working fine for the last couple of months as far as generating values (and can still generate values properly) but when I started to use some ports to read TTL signals, I encountered an odd problem, all pins are set to high. (and I mean ALL, even those not conneted to anything).
I checked the connector block myself, but all voltages were 0.06v or less, so it never made sense. I tried to write 0 to all the ports, and when I ran the read operation again, I got 0. Sounds like that solved the problem? No!
In fact, I had an infinite loop for the read operation, and I can see the value transitioning automagically from 0x00 to 0xFF in a matter of 15 or so seconds! I exhuasted all efforts in trying to reset the device, used the programmable power-up states to set them all to zero (which I think is the default), but with no avail.
Initially, I thought it was a problem with some of the wires in the connector block, but after I removed a few lines here and there, I didn't see any chages. I removed the cable from the PCI card and it's still behaving the same! So it's something internal to the board. I switched the board between two computers, same identical behavior.
As I said earlier, the card is still capable of generating values. It looks like that I'll end up sending the card for repair, but I was wondering if anyone faced a similar issue before doing so.
