01-04-2007 07:30 PM
01-08-2007 11:57 AM
02-05-2007 04:00 AM
I am hoping someone could give me a tip on how to set the right input voltage. I am using the NI 9211 and I‘ve used the custom scaling to convert voltage into pressure. The range of voltages i am getting is 28 to 70 mV. I’ve tried to set the right input range in the voltage input set up window, without success, I am still getting the error message 200077. I would appreciate if someone could give me a tip.
Thank
Glenn
02-06-2007 11:21 AM
02-08-2007 03:21 AM
I have used the table instead of the linear equation as the scaling factor and I have entered the corresponding expected minimum and maximum pressures obtain from calibration into the custom scaling.
Thank
02-08-2007 04:32 PM
