Digital I/O
Need to support about PCB Mounting Connectors (100-pin right-angle mounting)
Dear sir.
I need DW or dimension of PCB Mounting Connectors (100-pin right-angle mounting). I can't found
in this web site. Thank you
(5,425 Views)
Hello oatskii,
May I ask which product you are referring to and what your application is so that I can better help you?
Have you checked to see if the dimensional drawings in the references section of your product help you?  Not all products have dimensional drawings available
Anthony F.
Staff Software Engineer
(5,417 Views)
I am looking for the manufacturer drawings for connectors 777778-01 and 777779-01.
This is a 100 pin right angle PWB mount, and the 100 pin verticle PWB mount connectors. I am incorporating them in a PWB layout I'm designing that uses the NI USB-6509 interface.
Can you help, Anthony F.?
(5,203 Views)
Bigdaa,
Check out this link:
http://digital.ni.com/public.nsf/ad0f282819902a1986256f79005462b1/1679d7390b6d38e04825714a002cd4fe/$...
Hope that helps.
James K.
(5,192 Views)
Thank you very much, James.
David A.
(5,188 Views)
