06-11-2007 12:37 PM
06-12-2007 09:28 AM
03-11-2011 02:49 AM
Hi Andrew,
what about the stability in case of analog AC signals??
i have tried generating a sine wave of say 50hz and i do not get a constant frequency output at the PXI 6723 card.
Is this an issue with the card or the DAQmx driver??
03-11-2011 05:24 PM
Hi Henry,
Any variation in the frequency of your output signal will be a function of the jitter of the sample clock on the board. If you open the Cont Gen Voltage Wfm-Int Clk example (Help»Find Examples»Hardware Input and Output»DAQmx»AnalogGeneration»Voltage) how much variation do you see in the signal frequency? If you have a very precise clock (from a 6653 timing module for example) you could use that as the sample clock on your 6723.
03-14-2011 12:36 AM
Hi Sean,
In my case the frequency fluctuations while producing a single Analog Cont waveform is minimal but when i am simultaneously producing say 10 sine waves on the same 6723 card, then any change i make in the frequency of one wave is reflected uniformly in the other nine! what could the reason for this be. Also this behaviour occurs only in the case of decimal point change as in if i change from 50 to 50.2, but the same doen't occur when i am varying it to say 51Hz.
03-14-2011 05:14 PM
Hi ICs,
One thing to understand about the 6723 is that there is only one timebase for all of the analog output channels. What this means is that each channel will be sampled (updated) at the same time (See page 3-6 of the manual). Another thing to point out is that only a discreet number of signal frequencies can be generated because the sample clock is an integer divisor of the master timebase. So, for example, if you specify a sample clock rate of 60 Hz, what will actually be produced will be something like 60.002 Hz. You can find out what this value is by using a DAQmx Timing Property node:
Hope this helps!
