12-03-2005 08:32 PM
12-05-2005 04:32 PM
When the versions of DAQ drivers are significantly different, functions can often change slightly which can affect code execution. The first thing that I recommend doing is looking through the code itself and checking all of the functions, particularly the ones that generate errors. A good resource to compare these functions is the Traditional NI-DAQ (Legacy) C Function Reference Help. This is located in Start >> All Programs >> National Instruments >> NI-DAQ. I also found a couple of knowledgebases that concern the error -99. These appear to be for older versions of DAQ, but they are worth looking at.
Error -99 is returned when calling any DAQ function in Borland C version 4.5 for DOS.
What is NI-DAQ Error -99?
I hope this helps.
Hal L.
