I am currently using a NI 9472 module on a cDAQ chassis and controlling it with Diadem. When testing the module in NI MAX I can make all 8 LED's light up and the output works perfectly. However, when I switch over to diadem. Only outputs 0 and 1 work, outputs 2 through 7 remain off (LED does not even light up). The wiring, set up in Max, and diadem code is the exact same for all. How can I solve this issue?
Thank you!
