01-20-2019 11:48 AM
Hi there,
I am using a the USB-6212 board and I would like to generate a task in order to create a digital square wave at a given frequency (400 Hz). My problem arises from the fact that NI MAX only allows me to use only a software timed timing for such task. Did I miss something? Should I use the output from a counter of my board in order to generate a digital square wave?
Thanks.
01-23-2019 02:59 AM
it's not clear what you mean by "software timed timing".
Anyway, I tried to create a simulated USB-6212 and then an analog voltage output task. In the screenshot below you can see how to generate a 400 Hz square wave.
Hope it helps!
Alessia
01-23-2019 05:40 AM
The USB-6212 only has static DIO. This means they can only be software timed. The simplest thing to do would be to use one of the counters to generate your square wave.
01-23-2019 05:43 AM
1. No, your device doesn't support hw-clocked DIO, sometimes called "correlated DIO" and support on most other M-series devices. According to this article, your USB bus-powered device is one of the exceptions.
2. Yes you *can* generate such a square wave with a counter and as a bonus, it'll be much simpler than setting up correlated DIO. Check it out in MAX and then look at the shipping examples for Counter Output.
-Kevin P
