Digital I/O
NI USB 6210
Hi, I have the NI USB 6210 device for a low current measurement test I'm developing. I am currently trying to calibrate - what is the current in the circuit depending on the result of the USB 6210, and I noticed that when I supply low voltages then the results are not accurate...
There is this command - nidaqmx.constants.ADCTimingMode(14713) - BEST_50_HZ_REJECTION that should Improves 50 Hz noise, and I think this will solve the problem of inaccuracy at low currents.
I want to add this to the same task from which I read the value of the device.
I would appreciate it if you could help me how it can be implemented.
Or for additional ideas that can help me make the test more accurate.
Eden.
(1,271 Views)
Have you considered the accuracy specifications of 6210 for measuring such small voltages?
Santhosh
Soliton Technologies
(1,265 Views)
