07-28-2014 02:49 PM - last edited on 02-19-2024 10:51 AM by migration-bot
Hey All,
So i'm using the sbRio 9632 and i'm trying to upload to it. Where the trouble began was when I started uploading to the ni board. Upon completing the upload, an error occured (unfortunately I did not note the what error it was). Afterwards, I lost the target and the ni board was nolonger visible and also not communicating.
I looked at the LED indicator and it is showing a 2 flash/per second error which incidicates that something went wrong with the upload and the NI board software needs re-installing. The manual referred me to the Measurement & Automation Help topics to install the software, but I am unsuccessful in finding how to do so. I would greatly appreciate any tips in getting this board back into working condition. Please let me know if you need anymore information.
-Franky
07-28-2014 03:46 PM - last edited on 02-19-2024 10:52 AM by migration-bot
Hi Franky,
Should be straightforward to get your Single-Board RIO back in a usable state.
This tutorial walks through (re)installing Software on a CompactRIO (or Single-Board RIO) target.
https://learn.ni.com/learn/article/getting-started-with-compactrio-hardware-and-labview
If you are having any issues detecting the target in MAX (Measurement and Automation Explorer), then this article walks through debug techiques.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P70YSAS&l=en-US
For software purposes, CompactRIO and Single-Board RIO are essentially interchangable. The underlying hardware architecture between both targets is the same, so the process to load software or compile code is the same. I didn't want you to be alarmed that I'm pointing you to CompactRIO turtorials.
Hope this helps,
07-29-2014 07:43 AM
