02-11-2008 04:05 AM
for NI PXI 6562, for acquisition we can select data width of 1byte or 2 bytes for efficient onboard memory usage, so if we assign 1 byte, only 8 lines are for acquisition, therefore
Required Bandwidth = Acquisition Rate * Number of Channels * Memory per sample (Each line is 1 bit so 1/8 of a byte)
Using that formula, acquiring at 25 MHz we get 25MHz * 8 * 1/8 = 25 MB/s
So, there will be 25MB of samples will transfer through PCI Bus to controller memory and then write to HD, if my HD Write speed is 25MB/s average, streaming acquisition should work out smoothly, now the problem is that fetched data have been piling up in controller memory and subsequently it is full, unable to perform any more when it reach 100MSamples, How can I solve this problem?
for generation, data width is fixed at 2bytes for 16 channels so 1 bit for each channel,
Required Bandwidth = generation Rate * Number of Channels * Memory per sample (Each line is 1 bit so 1/16 of 2 bytes)
Using that formula, generating at 50 MHz we get 50MHz * 16 * 1/16 = 50 MB/s
Since 50MB/s is required, I tried to solve it by transferring most of my data to controller memory, I got an error message asking to reduce sample rate or write data to streaming waveform more frequently,
I would like to the bottleneck here, if I reduce the sample rate, data throughput is lower, I can do the streaming properly at 6MHz clk speed for 1GB of data, so is this the case of PCI Bus limitation for my 50MHz since it is required BW of 50MBps while 6MHz requires only 12.12MBps?
As you can see in picture attached, there is an increase in modular device on-board memory (space available in streaming waveform), as it increases, it will stop the application, we have 16MB of on-board memory, is on-board memory the bottleneck? How can I solve this?
One of my intention is to create some waveform in .hws format , write to onboard memory and repeat it, my only concern is that discontinuity between repition steps, can it happen ?
02-12-2008 02:28 PM
Hi Thet Khaing,
You are correct that the acquisition data width can be set. If you are acquiring data at 25MHz with a datawidth of 1 byte, the data will be acquired at 25 MB/s. For generation, again you are correct that the data width is fixed. However, there seems to be some confusion. The datawidth determines the sample size. It will not change based on the number of channels used. Therefore, at 50 MHz and a datawidth of 2 bytes, you have 100 MB/s.
Keep in mind that PCI/PXI is a shared bus. In order to sustain the generation and acquisition rates above, you will need to transfer data at 125 MB/s. Although this is below the maximum theoretical transfer rate of PCI/PXI (132 MB/s), in reality you are doing very well to get 110-115 MB/s. Furthermore, the PXI-8196 has a laptop hard drive. Laptop hard drives typically transfer data at a maximum rate of 25-30 MB/s. This makes the hard drive the bottle neck of the system.
From here there are several options:
1) If the generation waveform repeats, you could use scripting to link and loop waveforms. Unless you explicitly add a delay, there is no delay from on waveform to the next. In the script below, the first sample of wfm2 will occur on the next active sample clock edge following the last sample of wfm1.
script myScript1
Generate wfm1
Generate wfm2
end script
By using scripting, all the waveforms are loaded before the board starts generating data. This would reduce the needed streaming rate to 25 MB/s.
2) Adding hard disks in a raid 0 configuration would greatly increase the maximum transfer rate of the hard drives. It is important to note that hard drives perform best when read or writing from one file. If you are reading and writing to one disk at the same time you will see poor performance. In your case you may be able to use a raid disk for generation and the PXI-8196 hard disk for acquisition. Keep in mind you will not be able to transfer the full 125 MB/s, so you will slowly fall behind. Since you only need 2 GB of data the onboard memory should not overflow in the short amount of time you are streaming data.
3) There are other options if you need to indefinitely stream data at 125 MB/s, but they will be significantly more expensive. I will be happy to address them if needed.
Please let me know if you have any questions.
Ryan
02-17-2008 03:57 AM
02-18-2008 02:50 PM
Hi Thet Khaing,
I think you are referring to the Win32 File I/O examples. In these examples, the binary file is an array of U32, U16, or U8 data. It is important to note that there is no header information in the file, it is simply data. To create this binary file, you can use the LabVIEW or Win32 VIs (the hws VIs will not create this type of file).
Ryan
02-18-2008 08:13 PM
Can u pls show me a few steps to create a binary file in either using U8 array or U16array of data, as attached provided files do not have such examples for win32VIOs and using labview
Phone TK,
02-19-2008 10:21 AM
02-20-2008 02:15 PM
Joe Friedchicken
NI Configuration Based Software Get with your fellow OS users
[ Linux ] [ macOS ]Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
02-20-2008 09:49 PM
thanks a lot for the help, now i managed to create an binary file for 4 channels for generation,
however i got problem in acquisition, at the starting of my acquisition , a few data are lost but the rest is ok, for acquisition I used strobe for my trigger, can you pls help me how to prevent from losing data for acquisition?
i do not have any problem with acquisition storing the data as .hws file but we do not use it as it is device-memory dependent, I just used it to test of my lost data, very small file i send out , first i stored as .hws file and nothing is lost , same I did for my win32io VIs(e.g you can see in previous attachment), & still lost a few data at the beginning , so can you pls help me ?
Phone TK
02-21-2008 02:36 AM
we calculated the lost data size , and it happened to be 1Mbytes of data at the beginning and in addition we lostt 1Mbytes of data at the end of our data send(generated),
so now we are sure that we lost 1Mbytes of our data( it is consistent of losing 1Mbytes of data at front part of data and 1 Mbytes of data at the last part of data, in between data is correct,) happening for both generation and acquisition,
may I know how to solve this ?
attached is the screen-shot of generation session,it could be seen that Coerced # of Samples to Generate is smaller than Total Samples in File, could it be the reason that we lost our last part of data ? and pls help me advise on the data-lost at the begginning of my data .
thanks
Phone TK
02-22-2008 03:08 AM
Another scrreen-shot, as you can see attached picture, "Space Available in Streaming Waveform (Samples)" indicator is in negative value(-1153434), before i run the test, it is zero, may I know what does it refers to ? it too happens the same for sample written as showing -1 sometimes ,
Thanks & Best Regards,
Phone TK
