07-28-2017 12:30 PM
I was wondering if, for the NI PCIe6509, the lines can be changed as input/output on the run, meaning, if initially I set some lines as input I can change them to be outputs while I'm running a program. I know each line can be individually set as Input or Output but I don't know if I can change them on the run. If someone could help me with this I will truly appreciate it.
07-28-2017 07:01 PM
I know for sure if you close the task you can create a new one, turning what was as output into an input.
08-02-2017 09:21 AM
That's in LabVIEW right? What if I'm using the NI Measurement Hardware Driver Development Kit (MHDDK) in Linux? Any idea? For the application I'm using I can't use LabVIEW and I need to change the lines state from inputs to outputs on-the-go
08-02-2017 10:09 AM
I do use LabVIEW, but that is at the driver level that I perform the switching around. I know nothing about the MHDDK, so I will have to bow out here.
