09-28-2010 07:38 AM
I´m tying to get two SSR Outputs swichting, depending on incoming Signals.
Port0/Line0 is working but Port0/Line2 is doing nothing. (I also tried Line1)
I´m using MAX 4.6.2f1 Diadem 10.2, the channels are defined in DAQmx and can be choose in Diadem.
Any Ideas?
09-29-2010 04:15 AM
Hello Beenken,
could you please provide some more details:
1. what is your setup, what are your inputs/outputs, which hardware do you use
2. attach your DIAdem-DAC curcuit
3. technical MAX report
4. what is the concrete purpose of your curcuit
Thanks in advance
09-29-2010 06:55 AM
Sorry - my fault... I fixed the problem
