05-30-2018 07:55 AM
I have an application with two signals to be switched:
1.2-1.8A 18V
<1mA 3,3V (logic input with a 10k pull-down).
I would like to use a single device for both signals and NI 9482 meets the higher-current requirements, but it has no specification of minimum current nor details about relays or their contacts. Can I use this module? If not, what module could I use? I can use either CompactDAQ or USB interface devices.
Thank you.
05-31-2018 09:44 AM
Hey Paulius,
There doesn't seem to be a minimum for the relays. https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kFOySAM
However for best advise i recommend contact your local NI sales department directly. The engineers there will be able to help you in choosing appropriate hardware.
http://www.ni.com/contact-us/en-gb
Best,
-Jelmer
05-31-2018 09:57 AM
Hi Jelmer,
Thank you for replying. Your link has a white-space stuck to it. Fixed link.
The article concerns reed relays while the device I am asking about has electromechanical. Depending on contact material and relay design, the answer might be different.
I took your advice and sent a message to sales and will update the topic when they reply.
